Tomos BT90 project
93 berichten
Marv
Berichtdoor Marv » 09 mei 2011 12:05
We only have the AT, ATX, and NTX versions over here.
2pac
Contacteer 2pac
Berichtdoor 2pac » 09 mei 2011 20:37
We dont have BT here the only motorcycle tomos in the netherlands was the tomos ts50 with top speed of 85/kmh
Ive buy it on something like ebay in your country :shock:
-Rust in vrede Jan de lasser-
Tomos是颇有几分不同你知道
jordy1993t
Berichtdoor jordy1993t » 11 mei 2011 23:43
Wauw very nice i look it very much! How is the project going right now?
pomartin
Berichtdoor pomartin » 13 mei 2011 02:29
im still waiting for crankshaft...
pomartin
Berichtdoor pomartin » 29 mei 2011 16:08
update :D
i got crankshafts, some stickers and outside part of engine is half way pollished.
at the moment i do not have time for this... we got final exams in school and it ends 6.9.... so till then, this would be it
Afbeelding Afbeelding Afbeelding Afbeelding
Berichtdoor Alex.. » 29 mei 2011 20:56
looks great Pomartin, id like to see it when its finished, :)
ps; Could you inform about Ales, i havent heard from him since friday when he would sent me pictures, he was supposed to send all the parts tomorrow but i havent heard anything yet
pomartin
Berichtdoor pomartin » 31 mei 2011 22:27
update :D
more pictures and head tunning when i get new "small bearing" for crankshaft
@Alex... i will contact him ;)
Berichtdoor Alex.. » 31 mei 2011 22:31
looks real nice again Pomartin,
what cylinderhead do you use?
and ales has some problems with internet he said, so he responds very late or something,
so i guess its fine :wink:
pomartin
Berichtdoor pomartin » 31 mei 2011 22:41
cylinderhead is from Tomos CTX. it is good, becouse it has almost excellent squish, but i still need to make some measurements :P
pomartin
Berichtdoor pomartin » 01 jun 2011 19:40
cap for intake was made... still need to drill holes and polish it.
also found material for flange- inside fi 29
2pac
Contacteer 2pac
Berichtdoor 2pac » 01 jun 2011 20:53
realy nice :wink:
I have some question
I wanna give my bt engine more compression
i have a Bt cilinder High pressure cilinderhead and another exhaust 18mm intake and dellorthe 19mm carburater
Ive heard that there are 2 holes in the carter where your crankshaft is
if i fill them it have more compression
Can you confirm that?
And is there any limiter in the exhaust i have a NTX exhaust something like on a CTX
II hope you will help me :wink:
Tomos是颇有几分不同你知道
pomartin
Berichtdoor pomartin » 01 jun 2011 21:56
you can fill those holes in crankshaft with cork... it have some effect, and if something happens, cork is soft and it cannot do any dammage :D
it wont lift your compression, but performances will be better.
the only thing you can do for better compression is lowering cilinderhead
ctx exhaust has limiter. inside is a longer tube, wich disable resonant effect... and it have metal grid allover the exhaust
2pac
Contacteer 2pac
Berichtdoor 2pac » 02 jun 2011 10:24
Oke thankx
No not the holes in the crankshaft
but in the room where the cranckshaft is are 2 holes that are 5mm ore something they say to my :P
Tomos是颇有几分不同你知道
pomartin
Berichtdoor pomartin » 02 jun 2011 14:32
yes... you can fill them too.. make a thread and put in a screw. i recommend that you use metal glue too
2pac
Contacteer 2pac
Berichtdoor 2pac » 02 jun 2011 17:41
Oke realy thanx for you answer :wink:
Tomos是颇有几分不同你知道
pomartin
Berichtdoor pomartin » 02 jun 2011 22:02
no problem :D
2pac
Contacteer 2pac
Berichtdoor 2pac » 02 jun 2011 22:19
Now i have some work :P
Did it make alot of difference to fill that holes?
Tomos是颇有几分不同你知道
pomartin
Berichtdoor pomartin » 03 jun 2011 00:00
it depends on all other tunning... but it is positive difference for shore ;)
Berichtdoor Alex.. » 03 jun 2011 00:01
and Pomartin, do you know which piston you need for AT/BT/NTX Cylinder ?
pomartin
Berichtdoor pomartin » 03 jun 2011 00:37
well it depends on what fi of cilinder do you have... :mrgreen:
if you want to know which mark... there are a lots of marks of pistons for tomos... i use vertex or meteor, könig is also very good :D, i strongly reccomend that you do NOT use sukoki... it is very bad quality and toleranced for watercooled engines...
93 berichten
Gebruikers op dit forum: Baidu [Spider] en 3 gasten
