Tomos Sport R 45 Tuning how?
15 berichten • Pagina 1 van 1
Sagin
Berichtdoor Sagin » 17 sep 2007 13:54
Hello,
I'm from Germany and I don't find a site with guys who knows something abaout Tomos tuning. So know I'm here, I hope you can help me.
I have a Tomos Sport R and I want to tune it. I only will tune the power. I need some shops and some things that I have to buy, like an exhaust or a bigger cylinder etc.
Thanks
Ingmar.
Contacteer Ingmar.
Berichtdoor Ingmar. » 17 sep 2007 15:50
hello
if you want motortuning parts for your tomos you can go to http://www.scoots.nl
it is a ducht site i dont no if you no a litel bit dutch?
i dont know how fast u want to go but if u put a other cilinder 65 cc on your bike and an outher exuast (endy Reverse ) and a bigger carborateur 15 mm dellorto u wil go 75-80 km-h
Vragen of spullen nodig?
Sagin
Berichtdoor Sagin » 17 sep 2007 16:11
i will drive 65 km/h
i dont speek dutch, so can you call me the things i need?
Laatst gewijzigd door Sagin op 17 sep 2007 16:28, 2 keer totaal gewijzigd.
flopper
Berichtdoor flopper » 17 sep 2007 16:19
hi,
you can reach a speed from 65 whit 14/12 or 15/15 dellortho carberator, backchainwheel whit 22 tooths and for example a technigas exhaust.
my engish is very bad i knw 8)
Laatst gewijzigd door flopper op 17 sep 2007 17:45, 1 keer totaal gewijzigd.
Quote,
Sagin
Berichtdoor Sagin » 17 sep 2007 16:30
An exhaust doesn't go the German Police is very hard, so that's to remarkably!
So i think an 60 ccm kit is good, what do I need? only the kid and which kid is good?
What is a dellortho carberator, and a backchainhell?
Sorry my english is also not the best :)
T1nge
Berichtdoor T1nge » 17 sep 2007 17:03
bachchain thingy is normally called a rear sprocket :)
snorren is de bom
viewtopic.php?t=5931
keesos
Berichtdoor keesos » 17 sep 2007 17:07
you really need another exhaust, at least the one which is almost similar to the original one (only a little bit faster) it costs +/- €25,- . the orginal exhaust is to bad for a 60 or 70cc kit, that wouldn't give the maximum power. and it will go very slow.
Renault.
Createur d’automobiles
нαя∂¢σяє
Sagin
Berichtdoor Sagin » 17 sep 2007 17:23
ok,
but which exhaust looks like the original?
So please can you tell me some Best. Nr. for things I need?
So that i drive 60 - 65 km/h and nobody see it.
Thank you very mouch
keesos
Berichtdoor keesos » 17 sep 2007 17:38
http://www.scooterbromfietsonderdelen.n ... tlaat.html
that's the "fast" exhaust. I think the speed will be 55-60 but if you buy another carborator, (a 15/15 par example) you'll go 65. (and maybe another rear sprocket)
Renault.
нαя∂¢σяє
Sagin
Berichtdoor Sagin » 17 sep 2007 17:44
hmm but he never looks like the original :?
what is a carborator?
Do you meen that I dont have to buy a 60ccm kit?
flopper
Berichtdoor flopper » 17 sep 2007 17:48
yes, you dont neccesary need a 60cc kit 50cc is also enought to reach 65 .
a carburator is the thing who mixes your fuel and air, if you take a larger carburator you go faster because more fuel and air means: higher speed and torch.
You can find your carburator at the right from your frame, behind the plastic protection caps and above de gearbox. you can't miss it :!:
Quote,
Sagin
Berichtdoor Sagin » 17 sep 2007 20:24
Ok,
thank you.
So how fast can i get with a 60 ccm an 16/16 (or 15/15) Carburator an original exhaust? (and maybe another rear sprocket)
Because so the Tomos looks like an original.
flopper
Berichtdoor flopper » 18 sep 2007 17:05
Ok,
thank you.
70-85 kmpu whit a different exhaust
whit the original maybe, if you adjust the motor correctly.
Quote,
Sagin
Berichtdoor Sagin » 18 sep 2007 18:51
Ok i think i buy this things.
Cil.kit 60cc. met 3 spoelpoorten snel, aluminium cilinder met nikasyl cilinderwand.
(Standaard cilinderkop toepasbaar, wordt kompleet geleverd met zuiger, etc, (OPGELET PAST ALLEEN OP MODELLEN MET MEMBRAAN INLAAT))
Best.nr.: 2486
or bette this one?
Best.nr.: 11833
and a
Carburateur 16/16mm. Dellorto origineel model versneld (met olie-injectie aansluiting)
(Montage op Tomos modellen kan alleen waar al een Delorto carburateur met drukchoke op zit.)
Best.nr.: 4133
and a Tandwiel, the Tandwiel for a better acceleration, i know that my end velocity is slower. Which should I choose?
Thanks
ET
Berichtdoor ET » 20 sep 2007 19:15
i think you should get a tandwie; 22. then your moped will not pull up badly, but you still have nice top speed
