the motorbike tomos atx doesn't work pls help
nalis
Berichtdoor nalis » 09 dec 2011 13:52
Today I downloaded the cylinder to see what condition are the piston.All is ok.Not scored.Now the motorbike doesn't work.Whan can i do?smell of burning.Should it alignment?How to make a Tomos ATX 50? :? :cry:
Berichtdoor Alex.. » 09 dec 2011 15:27
did you put the piston back in the right way?
with the arrow pointing towards the exhaust?
Did you put new gaskets on ? (important, else it wont run)
do you have compression when you kickstart it?
