After Tuning no Power need help please
Sagin
Berichtdoor Sagin » 03 okt 2007 22:32
Hello,
i buy a 60 ccm motor and a 16/16 carburator from scoots.nl
but now i don't have power. With the old carburator the motor runs but i cant drive, The motor have power if i let the bike on the stand, but if i want to drive nothing goes (and he dont run in the no-load operation)
With the 16/16 carburator i have nothing, He runs but i dont can give gas.
By the new carburator is a second connection, for what is it? I think for benzin but i dont know it. I take the connection empty.
Please help me
Thanks
Berichtdoor Vuile Beunkoe » 03 okt 2007 22:40
The secon connection is probably for a Power Box (google it), but if you dont have one you should block that hole. Otherwise your F/A ratio wil end it like shit.
If the problem is not solved, you should check the spark plug, is has to be a lightbrown color. If it is wite, you need a bigger fuel jet, it's black then you need a smaller one.
Sagin
Berichtdoor Sagin » 04 okt 2007 15:56
it looks brown.
and now?
flopper
Tomos Supporter
Berichtdoor flopper » 04 okt 2007 15:58
do you have the second ''connection'' closed?
Quote,
Sagin
Berichtdoor Sagin » 04 okt 2007 16:14
yes
xanderz
Berichtdoor xanderz » 05 okt 2007 17:09
its an oil connector. it shows in the description of the carb u gave in another post. it probably works without it connected. jsut make sure u seal it off. else dirt and such can get in.
heres a link to the one most people use http://www.euroscooters.nl/shop/product ... cts_id=155
i reckon your tomos aint working properly as u didnt adjust the sproeiers(dont know the english word for it.) http://www.euroscooters.nl/shop/product ... ts_id=1764
those are sproeiers. they change your fuel/air ratio. if u dont have the proper ratio yout moped wont start, or atleast run bad.
i reckon with such a setup u need del'orto sproeiers and most likely it will be between size 65-70. depending on your exhaust. i really suggest u try to find a moped shop where they can do this for u if u dont have anyone to help you out. its hard to get the proper one.
grtz,
xander
EDIT: basic rule for adjusting yer sproeiers. after driving a few minutes on topspeed and u stop then the bougie should be coffee brown. but when your letting it run idle(stationair) your color will change so u cant totally depend on the color if u havnet driven a long while with it.
Terug naar “Opvoeren”
Gebruikers op dit forum: Baidu [Spider] en 1 gast
