Tomos BT90 project
93 berichten
Berichtdoor Ping » 03 jun 2011 17:26
[quote="pomartin"]update :D
i got crankshafts, some stickers and outside part of engine is half way pollished.
at the moment i do not have time for this... we got final exams in school and it ends 6.9.... so till then, this would be it
Is this crankshaft really black ?
If so , can you tell us more about it ?
Is it a special brand , it looks like a hardend type of crankshaft.
pomartin
Berichtdoor pomartin » 03 jun 2011 18:33
it is not black.. it joust seems on picture.
this is copy of CTX crankshaft, made in serbia, the other ones are original CTX. Originals are a bit better than copies, but the problem is that there is almost no good CTX original ctankshaft.
all of them have racing bearings ;)
2pac
Contacteer 2pac
Berichtdoor 2pac » 03 jun 2011 20:41
Oke
I wanna buy a ctx 90 or 80 engine but i cant find it so are they so special in your country?
-Rust in vrede Jan de lasser-
Tomos是颇有几分不同你知道
pomartin
Berichtdoor pomartin » 03 jun 2011 23:47
ctx is 80
e90 is 90
well, there is no such a problem finding an engine... but they are a bit expensive.. around 250 and 300€.. it depends on its condition
pomartin
Berichtdoor pomartin » 20 jun 2011 23:34
little update :D
There is a change in styling.
CTX rear forks with mono-amortizer :D .. and all what needs to be modificated :P
Afbeelding Afbeelding Afbeelding Afbeelding Afbeelding
Berichtdoor Alex.. » 21 jun 2011 16:46
as always looking nice :D
id really like to see it finished ;)
ps: do you know which gasoline/oil ratio you need for BT-Cyl, some say 1:20/1:25 and other just 1:40 , 1:45 ;)
pomartin
Berichtdoor pomartin » 21 jun 2011 21:58
3% of oil is usual ok.
If you use some cheap mark or non-syntetic oil i would reccomend 4%
with motul 710 (or better) is 2,5% enough.
And main rule: better too much than too few ;)
hehe i would like to see it finished too... its about time.. 26.6. will be exactly 8 months from when i started :P
2pac
Contacteer 2pac
Berichtdoor 2pac » 21 jun 2011 22:50
Okay 50x1,04 =52 that is 2 liter oil in 50 liter is" 1:25 "
Tomos是颇有几分不同你知道
brombertje
Berichtdoor brombertje » 21 jun 2011 22:53
4% is indeed 1:25
With good oil 2,5% - 3% (1:40- 1:35) is enough.
By the way, looks very nice. :)
pomartin
Berichtdoor pomartin » 21 jun 2011 23:01
tnx :D
I will start working on it again on friday, couse in thurstday we have last final exam :D
brombertje
Berichtdoor brombertje » 21 jun 2011 23:07
Good luck with the exam! :)
2pac
Contacteer 2pac
Berichtdoor 2pac » 21 jun 2011 23:17
yes good luck
i hope you finnish it :P
Than you can make alot of money for more intresting projects :D :D :D
Tomos是颇有几分不同你知道
pomartin
Berichtdoor pomartin » 21 jun 2011 23:21
good thing is that school will be over, bad thing is that ill have to move in another city where that school is, so ill be able to work on projects only in weekends :(.. till i find some garage or something in that city :P
93 berichten
